4770K Delidding Video from Tom, Release date ?
Dicehunter
Resident Newb
Roughly when can we expect the delidding video for the 4770K, Would love to do this but a video guide would be great :)
I'm not sure if somebody as influential as Tom should show this technique... Last thing he would want is inexperienced peeps wrekking there brand new haswell cpu's ...
There are many delidding videos of Ivy, the same methods apply to Haswell, I still don't have the balls to do it my 4670k :mellow:
someone posted a picture on here it's almost the same but there are pins sticking up under the lid you have to watch out for.
Was just curious as I wouldn't mind doing it but discovering that there are extra pins on the pcb compared to ivy I'm a bit put off just incase some TIM drips onto them and shorts them out :(
Apply the right amount and with a brush, you'll have nothing to worry about. If you are still put off then use non conductive stuff. Go to 13:00 of this video (it is Ivy) to see what I mean about the right amount and using a brush
I'm with you, I don't have the balls to do it to my 3770K lolol. If I did a badass custom loop I probably would, but I won't be doing that any time in the next 2 years so that can wait haha.
quite tempted to delidd after seeing those results
dont want to kill my 4770k though and i'm usually not good at those things
