4500 dollar budget gaming/fun pc Need tips and advice
It wont show the shopping cart it's cookies based so it won't work by linking it you will have to take a screen shot and post it.
I couldn't tell you how much it would be in $ you will have to find a US based supplier because strait conversions don't work because of UK tax.
I don't really know if it would do the job for what you need it to or if adding a better water block would help i'm a WC n00b as well all that i know is what i have learned from Tom's vids and a few posts here and there.
Hmmm well this is no beuno then xD
If someone could just compile a list of everything i need to make it happen. Like a res, pump, barbs, etc dont need specific parts but just a check list to go by. And then a good American vendor i could buy from would help lots. Thank you thank you
Jesse
Sorry dude, I can only help you with what I know. There are people on OC3D that know all about water cooling so someone else will definietly be able to help you out.
So this is what i have come down to for a custom kit
CPU block
http://www.performance-pcs.com/cata...cts_id=27126:78e962f515a639e052676193c689163e
Radiator
http://www.performance-pcs.com/cata...cts_id=26777:1156fa77000450b6eaead2783be231a4
Res/Pump
http://www.performance-pcs.com/cata...cts_id=30282:839282626ab7c44a00921c1059adfa78
Need a bit of help here will this bee good enough and work with what i have? it seems cheap compared to others..
Clamps
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=30173
Tubing
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=1953
I am not for sure if i want just clear with green dye or green tubing... What did tim use in his assassin build on youtube?
Barbs
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=21945
Will these be compatible and are they the right brand to go with?
Any suggestions would be appreciated thank you. Again green theme. And will the pump/res combo work with the 800d? thanks
Jesse
DazMode did a series of watercooling guide videos, this is the first of the series. It's good, it's good. It should help you in planning where abouts you want to start, and where you can go with proper watercooling.
EDIT part 20: Gone back to old [ yt ] tagging.
CPU block
Radiator
Res/Pump
Clamps
Tubing
Barbs
Jesse
I would change the radiator, to be honest to you. Haven't too much good on the EK one. You may want to check out the XSPC RX series, they are supposed to be brilliant. For the pump/res combo you got there: It will be perfectly adequate if you want to go CPU only, if you plan to add in GPUs you will need a stronger pump, maybe look at the Laing DDC series with a res top.
I did see an EXPC res/pump just like i have except it did say it was the laing thing.. What does that stand for i have no clue. I figured it was for something special...
