Thank you both. I had looked at the XSPC site, and realized the same. =/
As for performance PC, that's where I am trying to order all my gear from, in one large purchase. I have been researching for the last 2.5 months (on all assets of my new PC build). I am trying to recreate the loop that Tom did here:
Snow Drift - Water Cooled 690 II Advanced 6970 1100T Gadget Show Live System
[media]http://youtu.be/_YzbR3cHiNE[/media]
but with the larger RAD (and different fittings) in this video:
Coolermaster 690 II Advanced Watercooling Guide & Review B&W Black White
[media]http://www.youtube.com/watch?v=6tyJ7VGuoq4&feature=player_embedded[/media]
Here are all the water cooling items that I have looked into purchasing. Please keep note of the types of fittings and and nozzles that I have picked out. Is there anywhere I can cut corners here? This all adds up to about $510, and I haven't factored in the fan yet! Granted, the prices may drop a bit, because I am not going to water cool until I can get a GTX680 - might not be any time soon.
FITTINGS:
Koolance Swiveling 90 Angle Fitting, Single - Black: $8.99 X 2 = $17.98
http://www.performan...oducts_id=31840
Nozzle Single, *Black* Compression [13mm ID, 19mm OD]: $6.74 X 10 = $67.40
OD: 19mm (3/4")
Wall: 3mm (1/8")
http://www.performan...oducts_id=31103
TUBING: 2.25 x 10 = $22.50
PrimoFlex Pro LRT UV Blue Tubing -1/2in. ID X 3/4in. OD
http://www.performan...oducts_id=23370
RAD Bottom: $69.95
XSPC RX240 Extreme Performance Radiator Version 2
http://www.performan...oducts_id=25388
RAD Top: $49.95
XSPC EX240 Copper Dual-Fan Radiator
http://www.performan...oducts_id=32459
PUMP/RES: $49.99
XSPC X2O DC-750 - Dual 5.25" Bay-Res Pump/Reservoir Combo
http://www.performan...oducts_id=30282
CPU BLOCK: $49.99
XSPC Raystorm CPU Waterblock - Intel
http://www.performan...oducts_id=32331
GPU BLOCK: $159.99
eVGA Hydro Copper Waterblock for GTX 680
http://www.performan...oducts_id=33811
GPU Backplate: $19.99
eVGA GeForce GTX 680 Backplate
http://www.performan...oducts_id=33750
