After having probs with my mach1, I switched to a Vapochill LS and also a 3.4 Prescott.
However, when I clock to 4.3ghz, the processor shows as 10mhz !!! I have heard about this bug (ie its the highest 32bit number, so winXP just recounts from 0) but the question I have is:
Does anybody have a working solution to this problem?
A lot of software I tested for benchmark purposes will not run at this speed (ie Sandra, PC Mark 2004 etc) only because they detect the CPU incorrectly.
If there is no solution, then what is the point of clocking past 4.3Ghz??? It's a shame coz, this will run stable at 4.5+
After doing some more searching, I cam across this...
http://www.theinquirer.net/?article=14149
What are you other 4.3+ guys doing to get around this prob? I cannot find much, if anything, on Google.
