wotevajjjj
Hi
I connected my 3pin fans to the 4 pin header on the motherboard, ofcourse everything works, but it works at max speed now and I can't set it to a lower speed
I know you're all going to tell me to get a molex to 7v adapter or similar, but then I'd need to add a cable and I want to keep the pc as clean as possible.
On other boards I used, there was an option to set it to 3pin or 4 pin, but this one doesn't seem to have that option.
Any help ?
Any help ?
