Not had any issues, using old key advanced from around 2 years ago, try to link your 3dmark online with steam then find the dlc in steam store and dl the free or paid version, should just start to dl as game update.
Can I activate my existing 3DMark, PCMark 8 or VRMark product key on Steam?
Yes, this is possible. Just add your Advanced Edition key to the Steam client with "+Add a Game..." then "Activate a Product on Steam". Remember that the key will then be permanently tied to the Steam account it was applied to.
I just spent several hours downloading the latest 3dMark from a link on Futuremarks site, my BB is less than great needless to say. I go to install it and noticed it skips the Time Spy dlc with a message "time spy test is not a Futuremark dlc" or words to that effect.
The rest of the install appears to go ok, but I'm missing the Time Spy test.
Note: I wonder if I've broken something as I did have a very old 3DMark Advanced install (v1.1 I think) using a Key my friend got with his GTX 970's (he got two, both had a key, I had one) would that have confused things? My old key being from before Time Spy even existed.
I wonder if it's worth un-installing this old version to avoid any issues first? Actually, I just went away and did exactly that, then ran CCleaner. Re-installing had the same results & 3DMark was showing as the Advanced version again.
Any advice? I'm half tempted to just buy it via Steam, but was hoping my old version, updated, would at least let me use the basic Time Spy tests, albeit without the custom run options I'm used to. However, I might just get the same issues.
Scoob.
There's something seriously not right with this benchmark. I scored higher with my CPU at stock and my GPU running around 1300mhz (my relaxed clocks for non intensive games like Dead Island) and I scored more with the rig at lower clocks (5900 or so).
I know DX12 is supposed to leave the CPU alone but that really doesn't make sense. Annoying thing is it's a sodding demo so you have to go through that rigmarole every time you run it![]()
Not sure if this is really accurate yet. I mean look at the scores above, Wraith's 950 just outscored Killbane's 970...
2x 950sNot sure if this is really accurate yet. I mean look at the scores above, Wraith's 950 just outscored Killbane's 970...
2x 950sSLI always works well in 3DMark, every test we've run the 2x 950s have beaten a single stock 970 but as we've found when Kilbane adds a good OC they do get beaten.
Didn't realize it was SLI
