J jamesriley94 New member Feb 6, 2013 #81 The memory is at 1600mhz, 1.5v. No idea why that's displaying it for 1333mhz.
seumasbeathan Banned Feb 6, 2013 #82 jamesriley94 said: The memory is at 1600mhz, 1.5v. No idea why that's displaying it for 1333mhz. Click to expand... I meant vram Yeah, Im getting that to, its running at 2133, but they say 1333
J jamesriley94 New member Feb 6, 2013 #83 Errrm, vRAM isn't overclocked at all? But no, voltage and power limit are both maxed out in afterburner.
FredEx New member Feb 6, 2013 #84 My 6850 numbers suck, I have not seen any near as bad as mine. Maybe it is due to the CPU. I didn't save the results, but the first number was 39650. I see folks saying theirs is bad and they had over 121000.
D Damien c Active member Feb 16, 2013 #86 Finally managed to get this to run on my pc. 1st result was with stock gpu speeds but oc'd cpu. 2nd run with a small OC on the gpus made the scores go up but not much better. OC was +130 Core +300 Ram Last edited: Feb 16, 2013
F FTLN Active member May 6, 2013 #87 Heres my first run using this benchmark - 3770k @ 4.7 7950 @ 1100core / 1250mem / 1175vddc http://www.3dmark.com/3dm/615822 Max Temperatures - Last edited: May 6, 2013
yassarikhan786 New member Dec 22, 2013 #89 Crossed the 10K mark on Firestrike (Normal) with my 780 Ti (100Mhz OC on core and mem): http://www.3dmark.com/3dm/1946067 5494 on Extreme: http://www.3dmark.com/3dm/1945843
Cru New member Dec 22, 2013 #91 firestrike normal: http://www.3dmark.com/fs/821367 firestrike extreme: http://www.3dmark.com/fs/819814
