3d Mark 06 GTX 560 336 shader
FTLN
Active member
Looking for a bit of input on these scores... Good ? Bad ? Or room for improvement ??
Nice score for a i7-920
If you cant raise multi to X22 there isnt much to improve.If you can make a screenshot with gpu-settings,cpu-z(cpu),cpu-z(memory) and details from 3dmark.
Max multi on a I7 920 is x21.
But still a good score and your cpu migt be a real good one.
4.2 GHz 1,32 volt is great.
Have you tried with higher speed?
The real good I7 920 cpu can do about 4.5-4.8 GHz on air/water with around 1.45 volt.
