360mm Rad for the Corsair Carbide 540?
filmklub
Hi, I just tried my Alphacool Monsta 360 rad in my new case and it doesn't fit. Does anybody know which rads do fit? I would like a 360x60mm if possible.
thanks in advance!
Rick
I've seen a few builds with monsta 360's in the front, My trick is to get a cereal box and make a dummy of the rad including fans and see how it fits
I actually have the monsta rad and it doesn't fit. would need to cut loads of metal away. that's why i need a thinner rad
ok thanks mate. i know the alphacool ut60 fits with fittings at the bottom but i need them at the top (just to be awkward) thanks for yr help!!
