£300 to spend....what do i buy?
Ghosthud1
so yeh, got £300 to spend on some hardware!
specs are the same as in the signature.
also the rig is not housed in a case yet.
whats worth upgrading and whats worth getting? voice your opinions as im terrible at buying things.
A case?
A new case,like fractal design r3.
60-64gb ssd.
Cpu-cooler,like noctua nh-d14.
Some good casefans,maybe noctua`s or scythe gentle typhoons,akasa apache.
Obviously a case
It depends on what you are doing. A ssd wouldnt be bad, or a better gpu if you have multiple monitor setup.
A nice case blatantly, I'm assuming how much to spend on that would depend on how much you're spending on other things.
interested in an ssd tbf, what do you guys suggest as my board support sata III aswell.
Mushkin have some new SSDs coming out soon without the current problems Corsair and OCZ are having with their latest, I'd recommend taking a look at those reviews when they're released.
Another 4GB ram, you'd be suprised how useful it is even if only gaming - you can have a map editor, a game, 20 to 50 firefox tabs, messenger, steam, prime, and a few other things all open at the same time if you wanted
