Hi guys!
I'm looking for the highest performance GPU setup possible.
First off, I'd like to play BF3 with all possible eye candy at 5760x1200.
I first considered running two GTX 690's in sli, but I decided against it because:
-it seems quad-sli is pretty bad (micro-stuttering)
-2GB VRAM limitation when 5760x1200 is concerned.
I'd like to have both the gpu raw power of two 690's and no vram limitation of the 2gb 690's.
Based on this, I'm thinking about 3-way sli of gtx680 4gb for the following reasons:
-3 way sli is said to be quite good when it comes to micro-stuttering.
-4 GB of VRAM should be good for 5760x1200
-3 680 gpu's (present in 3way 680 sli) should provide about the same results as the 4 680 gpus (present in two 690's) due to scaling issues in quad sli.
-3 gtx 680 4gb cards are a bit cheaper than 2 690's
Please advise me if you think my reasoning is right or wrong.
Please advise me if you can think of a better solution.
Let me know if I'm missing any pro's or con's
Looking forward to your comments
Cheers
PS I currently have a Corsair 1200AX psu
Cheers
