3 Sticks of DDR2 ram
KuruOni
Okay so I have a Asus P5LP-LE mobo and two 1gb DDR2 PC2-5300 ram sticks. I upgradeed to 4gb of ram by adding one 2gb DDR2 PC2-6400 stick. Is it okay for the ram to be configure this way and also windows said only 3.37gb is usable
The RAM is fine like that. You may run into issues overclocking, but at stock it will run fine.
Are you running 64bit, or 32bit Windows?
Your memory config is fine.
If your on 64bit then your intergrated graphics may be using up some system memory.
3.37 gb is the limit(almost) of 32bit windows... Go to computer->system properties-> then it will tell you inside the System header which OS it is.
Well if it isnt intergrated graphics and your on 64bit os then it could be a bent pin in your cpu socket...
