Hi all fellas!
My name is Matt and I'm new in this forum which I found extremely helpful.
I have an ASUS M4A88TD-M motherboard which supports a maximum 16GB RAM and has 4 RAM slots and it also supports 2000MHz (O.C.)
My question is:
Can I buy 2x8GB RAM sticks, will the motherboard support this?
Or should I go for 4x4GB RAM sticks just to be sure it will work?
Another question I have is: If I buy Fury HyperX memory of 1866MHz, will it automatically O.C. with my system speed to run to according speed?
(Just in case I have an AMD Phenom II x4 965 3.2GHz)
Thank you for your attention!
My question is:
