K
Kyle
Guest
Hi guys, I just ordered a Cosmos 2 case :rock: and a GTX 660 Ti. I've got a bit of money left so I decided to get two 120mm fans to put on the side panel over the GPU. Now the thing is, I don't yet know how the front panel works; I'm assuming they provide the cables required to hook up the GPU fans and can thereafter be controlled with the front panel. I'm wondering if I would still be able to open the door fully (and not have to disconnect the fans each time I want to make adjustments). I'm going with a blue colour scheme and would preferably want LED fans. Would it be easy to hook up the LEDs and be able to control the speeds/lights with the front panel? Which fans should I buy?
EDIT: 100th post!
EDIT: 100th post!
