barnsley
born in a.....
Lets go from the top again, I'm a bit confused why your drivers had issues. Normally its pretty good at detecting multiple cardsAt least someone understands.
Which driver did you use, beta right? Try the non beta one again. It probably will work now. Weird idea I know but its worth a try. This time don't use DDU either. Just do it the way the driver wants to do it. Not normally a recommend idea but it could be due to something left behind by your 780.
Also how did you get the driver from AMD's site?
-edit- Its not that I doubt your ability to use computers, I just think something has gone a bit funky so it'll be cool to fix it for future reference
