The_Governour
I can get my hands on a new 250D for 50 euros and I was thinking of going a custom loop but I have a few questions.
How good and is the EK-SBAY DDC 3.2 PWM pump/res? Its a single slot version. As it is so tight packed then this could be a option - also later then I could all ways use the pump by it self in future builds.
With the optical drive mounted (with the possible Ek bay res) then could I fit a 120mm rad in then front as well? As I would like to at least have a 240 rad and a 120mm rad for the cpu and gpu.
