Here's my current rig.
It uses 3 x 4U ATX PC's all with Intel CPU/MoBo's.
They are boring and stock, but I will be building 3 x new 1U PC's using the Asus 785G EVO's.
They will work perfectly in a 1U because my PCI-e 1X Audio connector is all I will need in the slots of the Main PC.
Thanks to the Sideport RAM, I won't need a graphics card, hence the motivation to downsize.
I will be overclocking all of these AMD builds so I will be asking for tips here once I am finished with the builds.
Because I am a live performer I have to build this seperate from my live rig, and then it must be tested and ran for 72 hours w/o a hiccup. Then I will downsize the racks and dive into the 64 bit world.....
The mobo'swill be packed w/ 8GB's of RAM, and hopefully with help from guys here ( I know you kids are pretty smart ..) I will be running the RAM @ 1800MHz and a CAS 6-7 setting.
Below my soundcard is also a 1U ATX rackmount, and the pictured PCB had 6 x Analog Devices SHARC DSP chips, and 12 x AD21369 chips. Each of the new AD21369's is as powerful as a Dual Core Wolfdale running at 3.4GHz.
That sucker cost me 3500 USD.
Well hopefully some of you chaps will give me a hand at OC'ing @ 64bit w/ 8GB's in each PC.
I have a 1U QWERTY Drawer w/ a 4 Port KVM switcher for viewing all 3 x PC's.
The 1U DSP rack ( soundcard ) is all I need. The 3 x PC's are all connected via GigaBit LAN to a host application in the main PC.
My current rig has 3 x 4U Intel PC's, going down in size while increasing power is the logical choice, and each 1U PC will cost 1200 USD and that is really cheap considering my old 4U's were 3000 USD apiece.
Overclocking is something I have never done, but I have been lurking here for a long time, and have chosen this forum to be my knowledge base.
CiaoMein,
JAV
CiaoMein,
JAV
