180mm fan filter for fractal design arc midi
BlueScreen
Hello everyone!
It's been a while since I last posted anything on the forums. Now, however, things have changed a bit, since I finally started assembling new rig.
I've recantly purchased fractal design arc midi tower, and I am trying to find 180mm fan filter for the side panel. It turns out to be harder than I thought. So far I've only found one by silverstone. It's from US however.
Do you happen to know any European store (I live in Poland, but any UK shop would do just fine) where I could find this filter? I've been trying to find it on my own, but the results are rather miserable.
Also, does anyone happen to have this dust filter installed in arc midi? if so, then does it work well with it (like for example if grille on side panel and filter overlap, so the airflow isnt restricted)?
By the way, i might as well ask about decent 180mm fan. Do you know any that would provide decent airflow, without making too much noise and breaking the bank?
