N
nick25
Guest
Hello guys
Just bought the above keyboard and mouse for my other PC and I'm having a few issues as far as connectivity is concerned. Basically is keeps dropping out and/or the mouse becomes really laggy (to the point of being unusable). Does anyone on this forum own or have experience with one of these? I seem to remeber big Phil having it awhile back - not sure if you still do?
There is a bluetooth adapter (like a pendrive) which goes in a usb slot however the PC is behind me so the signal has to go through whoever is sitting at the desk - I didn't think this should be a problem (bluetooth 2.0 EDR supposedly has a range of 30m!) however I tried the bluetooth adapter in a USB extension lead so as it is right next to the keyboard/mouse and it is working perfectly. Obviusly I don't want to have a USB extension lead going over the floor (otherwise I would just use a wired k/m!) however I'm wondering whether I could plug it into the USB hub on my Dell monitor which would look quite neat & tidy.
Does anyone know if the bluetooth adapter can be plugged into a hub or does it have to be directly to the computer internal usb port? I would try it out but I don't have a long enough USB cable going from the monitor to the PC - happy to buy one if it is guaranteed to work ok though.
Sorry for the long winded post.
Cheers,
Nick.
Cheers,
Nick.
