ollietech
http://www.asus.com/ca-en/Monitors_Projectors/VG248QE#support_Download_36
ASUS_VG248_Windows_8_WHQL
If Windows 8 requires Microsoft certification for monitor, double click to install.
Can't paste a direct link, It's under utilities, I would use the DVI connection I don't see the point in using DVI-D for a DVI connection.
I've used this monitor only on my GTX 780. Try reinstalling drivers as we'll I have had weird GPU Driver issues with this monitor, a clean installation of the latest Catalyst drivers may do the trick for you. FYI changing the cable between different ports may cause a reset. Meaning you will have to go through the process all over again whatever your process may end up being... That driver signature did the trick for me hope you have the same luck
Also I think I actually used the signature that was on the CD that came with the monitor??? Cannot recall exactly but try both.
I have the VG23, i think its the older verstion to the 24 inch version.
theres no drivers for it apart from nvidia 3d stuff which i dont need as i have an amd card.
