grandpatzer
Just installed a Intel i5 2310 with Z68 motherboard
[font=Verdana, Arial, sans-serif, Helvetica]Overclocked max in BIOS +4 bins so 4 cores run 3.4Ghz Turbo mode instead of 3.0Ghz. [/font]
[font=Verdana, Arial, sans-serif, Helvetica]When running Prime95 according CPU-Z 3410Mhz but [/font]
Core Voltage 1.056v
[font=Verdana, Arial, sans-serif, Helvetica]<---- this sounds low no?[/font]
[font=Verdana, Arial, sans-serif, Helvetica]Ive so far run Prime 95 64bit for 20minutes and core temperatures are : 59C, 63C , 60C, 61C. [/font]
[font=Verdana, Arial, sans-serif, Helvetica]Temp 1: 48C, 2: 42C, 3: 53C[/font]
