Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
  #1
Old 04-02-21, 01:53 AM
DwarfAdigginAhole DwarfAdigginAhole is offline
OC3D Crew
AIO Questions for a 5600x.
So I was unable to get anything but a 5600x for my recent upgrade(Thanks pandemic). I want to push this thing to the absolute limits and I am hitting an issue. I have an old 2018 H115I Pro RGB and am planning to sell it to get a slightly beefier aio. I was looking between the EKWB 360 AIO or the Arctic LF 2 420. I can fit both really easily and, realistically I know the 420 should outperform the 360 by a mile but I am a bit of a sucker for the EK's looks. I was thinking about just buying three rgb fans and put the Arctic one in push pull to kind of make up for the lack in the looks department. What rgb fans would be good to go with the Arctic if I went with it?
__________________
  #2
Old 04-02-21, 02:53 AM
looz's Avatar
looz looz is online now
OC3D Elite
Sorry but I fail to see the point. At least see what the H115i can do before flipping it.
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #3
Old 04-02-21, 02:58 AM
OC3D Crew
Because my friend wanted an AIO so I planned to flip this and just get an overall upgrade.
__________________
  #4
Old 04-02-21, 05:31 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Are you going to have the fans in push or pull through the rad or even push/pull them?
__________________
DRAGON'S MIST
Coolermaster H500P White ARGB=AMD Ryzen 5950X=MSI Prestige X570 Creation=Intel Optane SSD 9 480GB PCIE=32gig 3600Mhz White Dom Plats RGB= MSI RTX 3080 Gaming X Trio=Coolermaster ML360R ARGB=MSI Optix MPG341CQR=Roccat AIMO 122=Corsair Force LS 960GB=Roccat Kone AIMO White=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with RBG strip=Windows 10 Pro=Thrustmaster T16000M HOTAS=MSI Agility GD60 RGB Mousepad=Chasepower Pure Sinewave UPS
  #5
Old 04-02-21, 06:18 AM
OC3D Crew
Push/Pull. Though I planned to use the fans that will be behind the radiator be the ones that come with the AIO.
__________________
  #6
Old 04-02-21, 06:46 AM
OC3D Elite
Ok firstly don't use different fans as they spin at different rpm's and can cause chop, noise and bad cooling performance, make sure all the fans you plan to use on the rad are the same.
As for the fans I'd go with the Lian Li uni fans https://lian-li.com/product/uni-fan-sl/
__________________
DRAGON'S MIST
  #7
Old 04-02-21, 08:31 AM
OC3D Crew
Sadly the Uni-fans for 140 are a no go. I cant seem to find them anywhere in the States.
__________________
  #8
Old 04-02-21, 09:49 AM
OC3D Elite
Can you get these over there?
https://www.ple.com.au/Products/6446...mm-Cooling-Fan
__________________
DRAGON'S MIST
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
