Hey guys, long time forum stalker, first time poster here.
Right now I am in the middle of building a new "budget" watercooled system and I would like to share some of my ideas with you and maybe get some productive feedback.
I guess I'll start off with how the idea for my new system came about:
A couple of months ago I got my hands on a dirtcheap 560mm radiator and since my old i5 just doesn't cut it anymore I decided that I will be basing my new system around the 560mm radiator. However, I soon came to realize that there are absolutely NO budget cases which fit said radiator size...
So while I was trying to find a case which would not cost me half a kidney I was also checking deals on different hardware.
I decided to build a Ryzen system, as of right now there's not much more bang you can get for your buck.
My mainboard choice was the CH6 Hero which I got for dirt cheap on ebay.
I already bought a new HX750i that will go inside and a Ryzen 2600 is on its way, together with a 500GB WD Black NVMe.
I will be transplanting some parts that are in use in my current system as well, such as
-my Inno3D GTX 980ti,
-16GB Teamgroup Nighthawk Ram (DDR4 3000, sadly it is Hynix),
-WD 1TB Blue HDD,
-Adata 240GB SSD (planning on using PrimoCache for creating a "SSHD")
-and my Corsair Commander Pro.
As for the watercooling, I will be using mostly new parts which I got for cheap or saved up for:
-alphacool 560mm rad
-corsair 140 ML fans
-13mm highflow fittings + hoseclamps
-EKWB Supremacy EVO
-EKWB RGB Res
-EKWB black tubing 13/19mm
- and my trusty Innovatek HPPS Plus which I stopped using for a few years (too much noise/vibrations), only recently I found out that I can solder a jumper for silent mode
So I removed the cap and took out the PCB to solder jumper 2 for silent mode and paint the cap black as blue didn't really fit the system.
I am aiming for a mostly black and gray colour scheme.
While the cap was drying I drilled a few holes into the Core P5 GT so that I could install the 560mm radiator. I have to say, it was a very tight fit.
Once I installed the radiator I used a riveting tool to install M4 rivets which allowed me to easily attach the brackets for the reservoir.
I still had the rubberfeet for the pump from many years ago and screwed the pump in place right below the reservoir. Luckily the mountingplate for the pump fit perfectly into the preexisting holes.
This is how the final tubing will look like, the pump and radiator will connect to the GPU:
Because I plan to switch out the GPU and RAM once I can get my hands on something affordable, I decided to use quick connect couplings for the GPU.
I planned out the tube routing in my head and started to connect the different components. I don't yet have the CPU but I installed the waterblock anyways. I put the mainboard into the case and proceeded with cutting the tubes into length.
I had to stop at the GPU connections, since I am still using the 980ti atm.
I was real fortunate to discover a problem with the quick connect fittings before I installed the whole loop!
The threads of the G1/4 fittings I am using are a bit too long for the O-ring to make contact with the quick connect coupling.
It was better to find this out now than when the loop is flooded.
Here you can see how the O-ring does not connect to the quick connect:
I then decided to cut the fittings into correct length with an angle grinder. Before I cut them I removed the O-rings, after cutting I grinded down the sharp edges and put the O-rings back on. This is a before and after comparison:
And here you can see how the O-ring should now properly seal the connection:
I was somewhat nervous when I first screwed in the now shortened fitting because I was not sure whether or not the threads would break after tightening the connection. They did not.
With the way I arrange the quick connect couplings I can also simply use an aircooled GPU in case I find a real good deal and have to wait for another good deal for a waterblock.
I almost forgot to mention the Corsair Commander Pro preparations.
I plan on using the Commander Pro to monitor and control my cooling and the lighting effects. The Commander Pro I bought some time ago included some thermal sensors which I intend to use this time round.
I bought an aquacomputer G1/4 thermal probe and replaced the actual sensor with the Corsair one (guaranteed to work).
Hence the first thermal sensor will be used for checking the water temperature, it is installed at the reservoir intake and the Commander Pro will then control the four 140mm radiator fans based on the water temperature.
The second sensor I simply slipped inbetween the VRMs and the VRM heatsink. I don't yet know if it will stay the way it is or if I will unscrew the heatsink completely and place the sensor right on top of an actual VRM. It all depends on how accurate the sensor reading will be (compared to HWinfo).
I also plan on somehow installing a movable 120mm fan at the back of the case which I can directly point at the VRM heatsink. The Commander Pro will then control this fan based on a custom fan curve, depending on the sensor reading.
My current system is running a baseclock overclocked i5 6400 on an Asus Z170-P board. If you BCLK OC on any Z170 board your board will lose the ability to properly read the actual CPU temperature. So I couldn't set up a proper fan curve and needed something that could. I didn't find any solution on the internet so I gave the Commander Pro a shot and as it turned out, it worked very well. With its help I set my custom fancurve based on my GPU temperature, it has worked flawlessly over the past 1,5 years so I plan to reuse this setup.
Just mentioning this in case anybody who reads this ever is in a similar position and doesn't know how to get a proper fancurve working in said case.
Right now I am looking for a german site that lets me order custom turned metal spacers...
I need them to install the top glass panel since it does not fit anymore after installing the 560 rad.
If anybody knows a site or somebody in this forum who does this for a hobby let me know, it would help me out lots!
I am sorry for the many missing pictures. At first I didn't intend to post this build at all but since I thoroughly enjoy following other people's builds I figured heck, why not.
I don't know how busy work will be, but I will try to keep this thread up to date.
As soon as the important missing parts are coming in, I will be using the PC as my new system. I will however keep modifying it.
Future plans are:
-putting in aluminium profiles for led stripes
-using foil to colour the case/components (mainly for hiding scratches but also for GPU backplate)
-figuring out how to install a movable fan
-sleeving PSU cables
-switching RAM for B-die (plus matching colours) and GPU for a newer one (possibly with vertical mounting)
-getting my hands on spacers and installing the top glass panel
-building a proper stand for the case out of aluminium profiles (the original feet look quite ugly)
-WD 1TB Blue HDD,
-EKWB Supremacy EVO
-EKWB RGB Res
Future plans are:
