Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
  #10601
Old 24-02-20, 02:31 AM
Bartacus Bartacus is offline
OC3D Elite
Originally Posted by WYP View Post
Ooooo. What's the build area on that? That's HUGE!
350mm x 350mm x 400mm I think. Here it is in action, next to a Lian-Li Dynamic O11 XL for scale:
My first test monkey is printing now! This thing was a breeze to set up. I am now having fun, for the first time in MONTHS!! Woohoo! This is using whatever filament Creality included with the printer:
__________________
Games: Ryzen 5950X on GB Aorus Master X570 / Asus TUF 6900XT / 32GB TridentZ Neo 3600CL16 (16GB x 2) / custom loop
Workstation: Threadripper 2950x on GB Aorus Xtreme X399 / Zotac 2080ti / 32GB TridentZ 3200CL14 (8GB x 4) / custom loop
Home Theatre: Ryzen 3900X on Asus C7H X470 / Radeon VII / 16GB G.Skill 3600CL15 (8GB x 2)
/ custom loop
  #10602
Old 28-02-20, 01:19 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
£450 all in. For absolutely no other reason than I was bored, fancy a change from the Titan XP and wanted something different.
I'm quite happy with that. It won't be as fast as my 2070 Super EXOC but that can't be water cooled and cost me the same. Plus this Asus Dual uses a 2080 PCB, with much better components (2080 stuff basically, all digital) and thus you can actually find a block for it. Don't ask me how I worked all that out it's taken me 3 hours :S
__________________
If you don't like what I post don't read it.
  #10603
Old 28-02-20, 05:08 PM
Greenback's Avatar
Greenback Greenback is offline
OC3D Elite
Got this coming tomorrow, Can't believe amazon stock was gone in less than a day.
Figure give it a go and being that it's amazon I have 30 days to return it or sale it for more than I paid
__________________
CASE: NZXT H440 white
CPU: RYZEN7 3700x, H100i GTX
MB: Gigabyte x570
RAM: 2x 8GB CORSAIR VENGENCE LED
GPU: Gigabyte white 2070
OS: CRUCIAL MX100 250GB
PSU: Corsair Rm850x
  #10604
Old 01-03-20, 05:28 AM
OC3D Elite
I finally got around to installing the Optimus AM4 CPU block. The flow rate improvement from a HeatKiller block is INSANE. I have no idea if this number is accurate, but what USED to be a 6.17LPM flow rate is now 8.93LPM. CPU stays under 60C at full load, so performance is good.
__________________
/ custom loop
  #10605
Old 01-03-20, 09:37 AM
FTLN FTLN is offline
OC3D Elite
Just picked up a EK Loop Connect, finally no more high pitched whining from my DDC 3.2 PWM.
Application that comes with it is pretty basic and no way I can find to hide it from the task bar or start with windows, no way to check in app what the current version of the app is or check for updates.
  #10606
Old 01-03-20, 11:57 AM
AlienALX's Avatar
OC3D Elite
EK can suck a fat one.
£200 for their new CPU block. Jokes.
Bitspower are now much cheaper.
__________________
  #10607
Old 01-03-20, 12:25 PM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Would the new blocks even make a noticeable difference?
__________________
Enthoo Elite | R7-5800X | X570 Tomahawk | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB, 840 Evo 250GB x 2 | EVGA SuperNOVA 1200 P2 | ViewSonic XG270QG, MX27AQ | Custom Watercooling Loop + Aquaero 6 XT
  #10608
Old 01-03-20, 01:32 PM
AlienALX's Avatar
OC3D Elite
3c.
£200.......
__________________
  #10609
Old 01-03-20, 01:37 PM
OC3D Crew
3c.
£200.......
Wow... Mad. If I need a new block...
How long does the average block last?
__________________
  #10610
Old 01-03-20, 02:16 PM
Greenback's Avatar
OC3D Elite
Depends on what you use as liquid and if you're willing to take t apart to clean, and if it fits the latest cpu, (if the company bring out replacement fittings) in theory you could keep it for a long time depending on upgrades and what comes out
__________________
MB: Gigabyte x570
PSU: Corsair Rm850x
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
