Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #11
Old 27-05-12, 03:41 PM
WYP's Avatar
WYP WYP is online now
News Guru
Originally Posted by Pr3d4t0r View Post
I run on max software voltage 1.087 I can lower to a minimum of 1.07 but its not as stable over time, bare in mind i have the palit sonic platinum, and im actually lucky to push it that far, but i need to get something like gelid ice as it gets to that 70C at full load and 70% fans(62 on 100%)
and OCZ i wouldnt want to use a low quality psu but im probably gonna go with tx750 or 850 if i can afford it
the only reason i own it was because my old psu started to make noises and i didn't have much money to get a better brand, it was at such a good price at the time. it runs fine it would take a hungrier system than mine to put it under full load. I have never had problems with ocz, but that's likely because i've not used their ram or ssd'.
i was curious about your voltage so i could approximate the additional power draw becouse of it, but since your board cannot use sli, i would recommend a 7000 series card if you are still planning to upgrade. the reduced power draw, temps and drastically better architecture, if you cross-fire eventually they have a new feature which turns off the second card at idle which will reduce idle power draw aswell.
__________________
_______________________________
Twitter - @WYP_PC
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
