Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
  #21
Old 28-05-20, 03:06 PM
looz's Avatar
looz looz is offline
OC3D Elite
Question, would someone enthusiastic about that brand be called a Nobhead?
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #22
Old 28-05-20, 04:23 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
It's probably the worst name ever tbh lol.
__________________
If you don't like what I post don't read it.
  #23
Old 28-05-20, 05:26 PM
Mr. Smith's Avatar
Mr. Smith Mr. Smith is offline
OC3D Elite
Originally Posted by Avet View Post
Yea. Any studio monitors will destroy gaming branded speakers. And I am constantly trying to make people buy them over regular speakers, but he asked for speakers to be as small as possible. Studio monitors dont fall into that category.
100% studio monitors are the best. There are smaller models and you don't need an amp or anything because the amps built in. Get a hum destroyer if plugging directly into pc.
  #24
Old 28-05-20, 05:39 PM
Kei's Avatar
Kei Kei is offline
OC3D Crew
Originally Posted by Dawelio View Post
Yeah, after some more advice I’ve steered away from 2.1 and now just want 2.0 system.
That link of yours, those are very nice, compact and cute looking. Why do I need a small amplifier? Do you have any recommendation for the purpose you mentioned?
They are also listed as ”passive”, what does that mean exactly?...
My JBL Control Ones are 22 years old. The first 14 years they were used in a sound control room at work. When this got decommissioned I got to keep 2 pairs of them. They are great rugged little speakers that do indeed go loud. The biggest advantages they have is that they are quite shallow speakers so can easily sit behind monitors and the reflex ports are front facing allowing them to be placed very close to walls without adversely affecting the sound quality. If anything, it helps to reinforce the bass as that's the only area they are really lacking. A 4" woofer in a cabinet that small is never going to produce masses of bass.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ 32GB Team 3200C14 ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ GTX 780 3GB
Enthoo Primo ⁞⁞ Seasonic Prime 750W ⁞⁞ Polaris SM961 256GB ⁞⁞ WD SN750 1TB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD 6TB, 4TB & 1TB
Samsung C27HG70 ⁞⁞ Ducky Shine 5 ⁞⁞ Intel X710 NIC ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B
  #25
Old 28-05-20, 05:59 PM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Nobheads and Schhit Stacks. Gotta love quirky names.
__________________
5000D | R7-5800X | X570 Tomahawk | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB | EVGA SuperNOVA 1200 P2 | ViewSonic XG270QG| Custom Watercooling Loop + Aquaero 6 XT
  #26
Old 28-05-20, 06:02 PM
looz's Avatar
OC3D Elite
"Amplified my nob with some Schiit."
__________________
  #27
Old 28-05-20, 07:29 PM
Warchild Warchild is offline
OC3D Elite
Its a bit Schiit really
  #28
Old 28-05-20, 07:31 PM
AlienALX's Avatar
OC3D Elite
Just don't ever put your nob in the schiit. It would be a real bummer.
__________________
  #29
Old 28-05-20, 08:12 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
Lmao!
__________________
Rig: Cpu: AMD R7 3700X. Mobo: Gigabyte X470 Aorus Gaming 7 wifi. Ram: Gskill Royal Silver 3200mhz cl16: Gpu: Msi RTX2070 Armor. Asus Xonar STX II.
  #30
Old 28-05-20, 10:45 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
I would try and avoid all PC speakers if you can. Mostly because even the best become far too expensive.
Get a decent set of monitors, and some stands if you need them. They will last you a lifetime.
https://www.amazon.co.uk/JBL-Control...0600634&sr=8-2
An example of. Get a small amplifier you can hide, job done. They have been winning awards for 25 years.
Got recommended these when looking at those JBL Control One. What do you reckon of these?: Renkforce Control 250AMP, being a bit cheaper.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
