Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #11
Old 18-05-13, 08:02 PM
chrisjones chrisjones is offline
Newbie
Send a message via MSN to chrisjones
Thanks for that info
Yes, but I was planning on using the quiet editions, which use 0.08A each according to Corsair, so that would be okay wouldn't it at 0.64A total?
Also, as for cable management, that will not be a problem, as I will have an absolute ton of time over the summer holiday to build this, and I will be building it over most of summer to make sure that I don't do anything wrong and have to rip it all apart..
__________________
Fractal Define R6, Asus WS390-Pro, Intel i7 9700k @5.2GHz, Corsair Dominator Platinum 32GB 3200MHz, EVGA RTX 2080 Super, Corsair RM1000i, Noctua NH-U12S, Samsung 970 Evo M.2 1TB SSD
Fractal Node 304, Asus Z87I-Pro, Intel i5 4670K @4.2GHz, Corsair LP 8GB RAM, Gainward GTX960, Corsair RM550, Corsair H75, Sandisk Ultra II 240GB SSD, 1x WD RED 3TB, 4x WD Green 2TB
  #12
Old 18-05-13, 08:04 PM
remember300 remember300 is offline
OC3D Elite
if you went for the link, you can put the nodes where the cables meet round the back, rather than run the cables all to one point
__________________
  #13
Old 18-05-13, 08:12 PM
Newbie
fair point, but where would I put the main control unit, because the only thing that I would have put in the drive bays would be the fan controller, and I don't think that the Link would fit behind the MB tray with all the other cables too.. This is a good idea though, so I will seriously look into it and see what the options are with this
__________________
  #14
Old 18-05-13, 08:31 PM
Snortan Snortan is offline
OC3D Elite
Yea,theoretically if you use the quiet editions you can put up to 12 fans per channel at 7V or 10 fans at 12V.
__________________
  #15
Old 18-05-13, 08:32 PM
OC3D Elite
the main unit fits in a drive tray its the same size a a hdd 3.5" the others are about 8mm tall, the main reason i like it is that it wont be seen from the out side
__________________
  #16
Old 18-05-13, 08:34 PM
Newbie
I would put a max of 9 on each anyway, but thanks for that
__________________
  #17
Old 18-05-13, 08:35 PM
Newbie
hmm, that's interesting.. what's the control software like for monitoring temps and controlling speeds?
__________________
  #18
Old 18-05-13, 08:47 PM
OC3D Elite
its corsair link erm i did a post a while ago showing it all but i can take some screen shots and put them back on this post if you like?
and i love it tbh you can have set presets or use your own fan curves
__________________
  #19
Old 18-05-13, 08:49 PM
Newbie
its okay, I'll have a Google and see what I can find on YouTube and pictures etc.
__________________
  #20
Old 18-05-13, 08:55 PM
OC3D Elite
i dont mind its only 2 mins of my time
__________________
Tags
corsair, fans, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
