Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
Thread Tools Display Modes
  #10441
Old 23-12-19, 06:55 AM
FTLN FTLN is offline
OC3D Elite
Originally Posted by Bartacus View Post
Overall score. Not sure if this is a proper link, but that run was here:
https://www.3dmark.com/spy/9812199
Nice score dude, but I'm sure you can squeeze a few more points out of it by setting that memory to 2100 , in nvidia control panel set texture filtering also to HIgh Performance.
Here is my score for an almost identical setup with my gpu core hvering around 2000mhz during the bench https://www.3dmark.com/spy/9814681 / GPU score = 7780
__________________
Intel Core i9 7980xe @ 4.5GHz @1.18v - MSI MEG X299 - NoName 2666mhz @ CL19 3200mhz - Thermal Take View Glass - PM961 1TB x2 - Aorous Extreme RTX 2080 Ti - 2 x 360 Rad + D5 Pump - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
  #10442
Old 23-12-19, 10:40 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
https://www.ebuyer.com/910955-benq-e...r-9h-lgtlb-fse
Will replace the 12 year old Samsung TV in my cave at mum's.
It's old, crap Res with 50mm borders. So even though it's only 32" it's freaking massive.
I want to enjoy gears 5 and RDR2 as fully intended.
I also bought fh4 last week when I logged in and a black Friday £10 voucher still worked, so I paid £19.99.
I thought fh3 looked amazing but God dayum 4 is stunning.
__________________
  #10443
Old 24-12-19, 08:38 PM
OC3D Elite
Just ordered this 3600 / 64gb kit from Scan in the UK : https://www.scan.co.uk/products/64gb...-18-22-22-42-1
Anybody know what IC's they will most likely have ?
__________________
  #10444
Old 24-12-19, 08:40 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by FTLN View Post
Just ordered these from the UK : https://www.scan.co.uk/products/64gb...-18-22-22-42-1
Probably SK Hynix, Corsair tend to save their Samsung stack for their Dominator series.
__________________
=Origin-Steam-Uplay-XBLive - Dicehunter=
  #10445
Old 24-12-19, 10:28 PM
OC3D Elite
Thanks, another strange thing is that product page title says 3200mhz but Product overview and Technical specifications show 3600mhz and also manufacturer code is CMW64GX4M2D3600C18 which is also 3600mhz (I found the site actually searching for this kit in google with the manufacturer code).
What are do you reckon my chances are of getting the 3600 kit ?
Has anybody here bought from Scan before ?
__________________
  #10446
Old 24-12-19, 11:11 PM
Dicehunter's Avatar
Resident Newb
Well it says 3600MHz in the model number section and memory speed section so you should be fine, I've been buying from Scan for around 10 years and they tend to be pretty good.
__________________
  #10447
Old 25-12-19, 08:47 PM
Dicehunter's Avatar
Resident Newb
Phillips Fidelio X2HR, These used to be upwards of £200, Managed to get one for £99 brand new, Plugged them into the AE-9 and definitely brought a smile to my face, A lot of people in the audio community call them "fun" to listen to, Can definitely see why.
Headphones specs -
Acoustic system - Open
Diaphragm - LMC
Frequency response - 5Hz - 40,000Hz
Impedance 30 Ohm
Magnet type - Neodymium
Maximum power input - 500 mW
Sensitivity - 100 dB @ 1mW
Speaker diameter - 50 mm
Distortion - <0.1% THD
Type - dynamic
__________________
  #10448
Old 25-12-19, 09:19 PM
AMD Enthusiast
I know exactly how you felt Dice. First time I used my Beyers Amiron Home I got that same fun feeling and probably smile
__________________
I am Iron Man.
  #10449
Old 26-12-19, 03:17 PM
Dicehunter's Avatar
Resident Newb
Yeah it's difficult to describe, Just kind of brings a smile to your face
__________________
  #10450
Old 26-12-19, 04:29 PM
AlienALX's Avatar
OC3D Elite
T5P. The only headphones that do every thing like that.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
