Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
Thread Tools Display Modes
  #10431
Old 22-12-19, 01:52 AM
Bartacus Bartacus is offline
OC3D Elite
Well I caved. It was $200 off, and I used all the points I had with my local nerd store and got this:
Then I dressed him up in a fine German tuxedo:
Now this is my first 20xx series card, so I'm not sure what the deal is, but after applying a +200 core +600 memory overclock, the card appears to boost to 2115mhz without a problem. And the best part is it has the lowest GPU temps I have ever witnessed under full load. It almost makes me think something is wrong, since it maxes out at 35C. Tops. At 2115 core, 7600mhz memory. I mean I knew Arctic Cooling MX-4 was the shizzle, but this is crazy!
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #10432
Old 22-12-19, 03:37 AM
Avet's Avatar
Avet Avet is offline
OC3D Elite
That is the power of water. I love Watercool blocks.
__________________
Turbos on an engine is God's way of telling you it ain't got enough cylinders.
  #10433
Old 22-12-19, 03:47 AM
OC3D Elite
I've never seen consistent temps this low though, even with previous Heatkillers. My 1080TIs run around 10C higher with similar overclocks. This is insanely impressive! I'm going to start bumping up the clocks, since apparently +200core / 600mem is milk and cookies for this GPU. I wonder if I won the silicon lottery for once, LOL!
__________________
  #10434
Old 22-12-19, 02:22 PM
Avet's Avatar
OC3D Elite
I find this page briliant:
https://www.overclock.net/forum/69-n...er-s-club.html
A and Non-A gpu are listed, and most importantly power limits. Really helps when you are shopping for a GPU. Ofc. if you are not hunting for deals.
Note: In your description for SSD you wrote "SX9200 Pro". It doesn't exist. It is SX8200.
__________________
  #10435
Old 22-12-19, 02:32 PM
OC3D Elite
Already posting in that thread this morning. Been doing more GPU testing this morning, up to +275 core +750 memory, temps are still insanely low. I must have accidentally done the best GPU block mount ever, LOL!
P.S. thanks for the spot, typo corrected!
__________________
  #10436
Old 22-12-19, 05:02 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Wait until it starts ray tracing hard. Load up Metro Exodus and max out RT. My 2070s got rather angry when I did that lol.
Love the block. Gorgeous.
__________________
  #10437
Old 22-12-19, 05:18 PM
FTLN FTLN is offline
OC3D Elite
Any chance you can do a Timespy Extreme & post results, that looks like a wicked card
__________________
Intel Core i9 7980xe @ 4.5GHz @1.18v - MSI MEG X299 - NoName 2666mhz @ CL19 3200mhz - Thermal Take View Glass - PM961 1TB x2 - Aorous Extreme RTX 2080 Ti - 2 x 360 Rad + D5 Pump - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
  #10438
Old 22-12-19, 06:59 PM
OC3D Elite
I had to back off on the clocks a bit. Superposition would run at +275 core, but Time Spy died instantly. So the current clocks are sitting at +250 core +750 memory, and still cannot break 35C, even after back-to-back Time Spy Extreme stress tests. Mind = blown!
Time Spy Extreme just ran now, score was 7462. According to Afterburner, the core topped out at 2190, memory topped out at 7750.
__________________
  #10439
Old 22-12-19, 10:04 PM
OC3D Elite
Is that graphics score or overall score ?
  #10440
Old 23-12-19, 01:02 AM
OC3D Elite
Overall score. Not sure if this is a proper link, but that run was here:
https://www.3dmark.com/spy/9812199
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
