Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics - Other
Thread Tools Display Modes
  #1
Old 08-01-14, 10:23 AM
JoshVDS1 JoshVDS1 is offline
Newbie
Send a message via Skype™ to JoshVDS1
BF4 on GTX 770 at 5760X1080
Just wondering if i can run BF4 at 5760X1080 with a 770 ro do i need to run in SLI? If so can someone plx exlpain how i can set this um in the settings? thanks
  #2
Old 08-01-14, 11:30 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
You will struggle playing on anything higher than low settings at that res with one card to properly do it you need a second card, as to how to set it up I cannot say as I run AMD and never done it with Nvidia, but don't worry someone else will let you know.
__________________
DRAGON'S MIST
Coolermaster H500P White ARGB=AMD Ryzen 3700X=MSI Prestige X570 Creation=Intel Optane SSD 9 480GB PCIE=32gig 3600Mhz White Dom Plats RGB= Sapphire RX5700XT Nitro Plus=Coolermaster ML360R ARGB=MSI Optix MPG341CQR=Roccat AIMO 122=Corsair Force LS 960GB=Roccat Kone AIMO White=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with RBG strip=Windows 10 Pro=Thrustmaster T16000M HOTAS=Razer Firefly RGB CE=Chasepower Pure Sinewave UPS
  #3
Old 08-01-14, 12:15 PM
jamesriley94 jamesriley94 is offline
OC3D Elite
I used to run 5760x1080 on a single 670, and dropping settings down to medium meant my FPS never dropped below 60.
It's actually quite disorientating playing at 5760x1080, so I'd opt for a higher resolution screen rather than triple screens but it's up to you of course.
Setting the screens up on a single 770 is easy though - plug two in to the DVIs and the other one in HDMI, activate Nvidia surround and it should work fine.
Tags
bf4, gaming, gtx 770
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
