Go Back   OC3D Forums > [OC3D] Graphics & Displays > Drivers & BIOS
  #1
Old 27-03-20, 12:51 PM
Nine Iron Nine Iron is offline
Member
saved BIOS profiles compatible after update?
I'm thinking of giving a new BIOS a try - one that's four or five generations more current - and I want to preserve my settings. I know (the hard way) that profiles saved to my BIOS's chip are wiped by a flash, but let's say I save a v2605 profile to a USB stick - would I be able to load it up in BIOS v3003?
For the record, it's a ROG Strix B450 - I don't know whether this kind of thing would vary between manufacturers, I'm just curious as to whether anybody has done it in the past.
If it's a "no", I guess I'll just have to bite the bullet, take a load of pics on my phone, and key them all in manually.
Cheers,
9I.
__________________
Ryzen 5 3600
MSI B550 Gaming Carbon WiFi
16GB Patriot Viper Steel 4400 MHz
Gainward 1070
ADATA SX8200 512GB, Intel 660P 2TB
LG BH16NS55 BD-RE
EVGA 650 P2
  #2
Old 27-03-20, 03:34 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
My experience with the profiles is they break almost always when using profile from earlier bios. pics with phone then try using the saved profile, worst case it wont work but you may get lucky.
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Custom Loop | Patriot Viper Steel 4133 @ 3600 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Barracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho Pro Tempered Glass | Windows 10 and Linux Manjaro
  #3
Old 27-03-20, 05:25 PM
Member
Given the number of AGESA updates between my current BIOS and the latest one, I'd probably be better off doing a completely new OC. Chances are I'll end up with something better, and it's not as though I've anything else to do at the moment...
__________________
Ryzen 5 3600
Gainward 1070
LG BH16NS55 BD-RE
EVGA 650 P2
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
