Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 25-04-12, 03:27 PM
Slav2012 Slav2012 is offline
Newbie
Ok so Ive got my old rig outa the garage as i want to test it and have some fun with it. So specs are below
XFX nForce 780i SLI motherboard
Intel Core 2 Quad Q9400 2.66Ghz
Mushkin/Ocz 8GB DDR2 800mhz
Evga Gtx 285 superclocked Edition
Inno3D Gtx 285
Thermaltake Toughpower 750w modular psu
Ok now thats the stats or atleast what matters. My current Power needs are 595w on average with the current system. My motherboard has 3 way sli compatibility or i can just use the 3rd pcie slot to use a physx card while my gtx 285 run in sli.
So my question is what card is good enough for purely physx along side my sli gtx 285.
Now concider i have a 750w psu so this will barely sneak in but i can change the psu if i have to the main part is what is good enough as a physx card.
Would a 9800Gt or 9600Gt cut it? or maybe even a gts 450.
  #2
Old 25-04-12, 04:04 PM
marsey99 marsey99 is offline
OC3D Elite
96gt would do just physx but idk if it would just be better doing both on your current gpu as others have tested it in the past and adding a 2nd weaker card has been known to slow it down overall.
  #3
Old 25-04-12, 05:41 PM
KING_OF_SAND KING_OF_SAND is offline
OC3D Elite
GT430
  #4
Matthias2437 Matthias2437 is offline
Advanced Member
Yeah a 9800 should be good. I had my GTX 9800+ in my gaming PC for a while with 2x GTX 570s and it some things I would get a slight performance increase. Not really that noticeable though.
  #5
Techie103 Techie103 is offline
Member
I would definitely lean towards the GTS 450 for physx.
__________________
  #6
Old 25-04-12, 06:26 PM
Rastalovich's Avatar
Rastalovich Rastalovich is offline
OC3D Elite
In an sli rig, a separate physx card should be slower.
__________________
  #7
Old 25-04-12, 07:09 PM
OC3D Elite
It's hit and miss.
  #8
Old 26-04-12, 03:29 AM
airdeano airdeano is offline
OC3D Elite
wasnt that kinda the thinking was to use an older card, until the appropriate card was located to complete the package?
usally i found that a bit-rate compromise was the "bottle-neck" jumping from a 192-380 bit-rate to a physx 32-128 actually
slowed the performance down. but consistant bit-rate (128 with other 128's) cards seemd to play well with each other.
airdeano
  #9
Old 26-04-12, 09:40 AM
equk's Avatar
equk equk is offline
OC3D Elite
I thought there were tests done that proved that having a slower 'dedicated' physx card actually hindered and bottlenecked the system?
*goes to find thread with video*
[media]
__________________
i5-2500K @ 4.8Ghz | 16G DDR3 | P8Z68-V GEN3 | Archlinux | Ryzen 7 Soon?
  #10
Old 26-04-12, 09:46 AM
OC3D Elite
Is what I thought, but I don't know if it was tested on something greater than 2x285.
If it were 2x470 or 480, I'd definitely say not to bother.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
