Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 20-04-12, 07:33 PM
Matthias2437 Matthias2437 is offline
Advanced Member
I recently built a PC and am using the Corsair H100 as my cpu cooler. I want to do push pull but can't decide on what fans/screws to use and would like some recommendations. I know that Noctua makes some pretty fantastic fans but they also are a little pricey, but considering what I just spent on this computer I guess I wouldn't be opposed to them if I actually get a noticeable benefit to my CPU temperatures. Color of the fans and lights are not really a factor in my decision, really just performance.
Thanks for any suggestions!
  #2
Old 20-04-12, 07:36 PM
PetrolHead247's Avatar
PetrolHead247 PetrolHead247 is offline
OC3D Crew
Akasa Apache's for sure. Just as quiet as the Noctuas and perform extremely well too plus they're cheaper.
Also, if it was me i wouldn't run a H100 with push pull as you only loose a couple degrees, so imo it's not worth it. However, if you have the money and the case to handle the fans go for it!
__________________
My Rig - Vanquish (Pics Here!)
CPU: Intel Core I5 2500K :: Mobo: Asus P8P67 :: GPU: Asus GTX 670 DCUii :: RAM: Corsair Vengeance LP White 2x4GB 1.35v :: CPU Cooler: Corsair H100 w/Corsair SP120 QE's
SSD: Samsung 830 256GB :: HDD: Seagate Barracuda 500GB 7200.12 :: PSU: Corsair AX650 w/ Individually Braided Cables :: Case: Fractal Design Arc Midi :: Monitor: Asus VS228H
  #3
Old 20-04-12, 07:43 PM
Jadarite's Avatar
Jadarite Jadarite is offline
OC3D Crew
Send a message via MSN to Jadarite
The noctua nf-f12pwm are the one's to use with the H100 imo and as petrolhead said just use two fans
http://www.google.co.uk/products/cat...AA#scoring=tps
__________________
"The answer to life the universe and everything is 42 "
Power Supply Calculator Guide (you might have to F5 this)
  #4
Old 20-04-12, 07:50 PM
Advanced Member
That answers all of my questions perfectly! I wasn't sure what kind of performance increase, if any I would get from push/pull on that cooler so that is good to know. Also I spent about $2700 on this build so I am going to check out those fans, if they perform as well as Noctuas but for a little less cash then I am all for it.
Thanks
  #5
Old 20-04-12, 07:59 PM
Kyze's Avatar
Kyze Kyze is offline
Member
Nice to have a cheaper alternative to the noctuas!
But they look just as bad as them..
__________________
My Rig in the Gallery!
  #6
OC3D Crew
No problem
The Apache's are £11 compared to the NF-F12's £19 and from what i've seen in reviews the Apache's perform very very close to the NF-F12's, and they are both super quiet too
__________________
  #7
Old 20-04-12, 08:42 PM
tharionos tharionos is offline
OC3D Crew
noctua NF F12's hands down
__________________
  #8
Old 21-04-12, 06:05 AM
airdeano airdeano is offline
OC3D Elite
a little window shopping and i found noctua f12's in the states on a easy budget.
i believe im not supposed to advertise their name on this forum, but youll see
a lot of reviews of unboxing, reviews and other tech tips on his youtube channel.
and they do have a state-side warehouse. selling at 15.75 each. i got 12 freight
paid on the way for that price.
airdeano
  #9
Old 21-04-12, 06:41 AM
Cyanide89 Cyanide89 is offline
OC3D Elite
Noctua fans I you must do push/pull. But it's not necessary with the H100. For me at least. My temps are currently below 50 under stress tests.
  #10
Old 21-04-12, 04:22 PM
OC3D Elite
[sub]if push/pull, use the f12 as push and the p12 as pull. there is no need to focus the exhaust, you just wanna dispurse[/sub]
[sub]the air from the radiator. so if the top fan set is visable, you can use an different fan for the job.[/sub]
[sub]airdeano[/sub]
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
