  #1
Old 09-11-17, 08:51 AM
Strechy0 Strechy0 is offline
Newbie
Intel Core i5 8600K Build
Hi peoples
Time to upgrade from my I5 2500 and 560TI its not coping very well with COD WW2
How does this look
https://www.pccasegear.com/wish_lists/768057/CL
Thanks
  #2
Old 09-11-17, 10:31 AM
WYP's Avatar
WYP WYP is offline
News Guru
Are you planning on upgrading the whole system at once or bit-by-bit?
Either way that should be a huge upgrade for you, though I would recommend an AIO cooler over a large air cooler these days.
  #3
Old 09-11-17, 10:52 AM
Newbie
All at once was a bit on the cautious side of aio coolers of them leaking what would u recommend for aio if I go that way
  #4
Old 10-11-17, 12:37 AM
SeanAngelo's Avatar
SeanAngelo SeanAngelo is offline
Member
Originally Posted by Strechy0 View Post
Hi peoples
How does this look
Thanks
looks good. do you really need 750W? 650W is plenty. May even go down to 550W. As for AIOs, the H100i V2 is really good. Though the fans are quite load when temps get high, I'm personally thinking of buying new fans for mine.
__________________
i7 8700K | Noctua NH-U14S | Asus Maximus X Formula | G.Skill TridentZ RGB 4x8GB 3200Mhz | EVGA RTX 3080 FTW3 Ultra | 2x ASUS ROG PG279Q
Samsung 860 EVO 1TB/500GB - Samsung 970 Evo+ 500GB - Sabrent Rocket 1TB | Corsair RM650x | Lian Li Lancool II Mesh | Corsair K70 MX Reds
Logitech G502 LS | Beyerdynamic DT770 250Ohm | Microlab FC330 2.1 | ASUS STX II
  #5
Old 10-11-17, 01:13 AM
AMD Enthusiast
I would just buy the 1080 you want first and see how that goes.
If you have the money then I don't see an issue with list except for the PSU. Could get away with a 650watt.
As for the AIO, for that price you could probably get away without spending too much more for a solid AIO. Corsair/NZXT make good ones.
  #6
Old 10-11-17, 03:21 AM
Newbie
Yeh only save about 15 bucks if I get a 650 so not really a big deal there I like the NZXT AIO but so dam expensive
  #7
Old 10-11-17, 03:23 AM
AMD Enthusiast
The H1xx series from Corsair are cheaper and still very nice.
  #8
Old 10-11-17, 03:25 AM
Newbie
Yep should I go for the bigger 240 or the smaller 120
  #9
Old 10-11-17, 04:12 AM
AMD Enthusiast
I wouldn't bother with any 120 AIO personally. I would get the 240.
Which one you looking at in particular?
edit: Just curious but have you looked into Ryzen? I was looking at prices and it's so much cheaper. Granted it will be slower but just worth a mention if you wanted to save money.
  #10
Old 10-11-17, 04:24 AM
Newbie
I was looking at the Corsair H100i V2 just not that keen on Ryzen really but it does sound like its getting a lot more popular
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
