Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 15-08-18, 08:43 PM
SebastianAltena's Avatar
SebastianAltena SebastianAltena is offline
Newbie
Question 8800 gts thermal pad thickness
Long story short: my gpu died, dropped in 8800GTS, it overheated, cleaned the cooler didn't help, removed the cooler to replace thermal paste and thermal pads on ram turned to dust.
So what thickness pads should I buy?
  #2
Old 15-08-18, 09:45 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Thermal pads for the older Nvidia cards were 1.0mm thick and 1.5mm on the AMD equivalents at the time.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #3
Old 15-08-18, 09:58 PM
Newbie
Ordered 1.0mm pads. You are a lifesaver thank you.
  #4
Old 16-08-18, 12:05 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Listen man just be careful. I had a 8800 Ultra I ended up bending quite badly because I got the wrong pads.
I'm not saying Wraith is wrong (far from it) but yeah, just go easy.
__________________
  #5
Old 16-08-18, 01:12 PM
Wraith's Avatar
Bettyswollocks
Tis true, I've read other older forum posts (not just OC3D) with the same topic and they have replaced using 2.0mm with the idea that the pads are soft and squishy which causes all sorts of issues.
__________________
  #6
Old 16-08-18, 02:19 PM
AlienALX's Avatar
OC3D Elite
Aye, they really don't have much give in them at all.
I would do a dry run (so no thermal paste) and very gently do it up and make sure everything is home before going any further.
Mind you, I had just baked the card for a third time so it really was screwed any way.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
