Thread Tools Display Modes
  #261
Old 11-12-18, 09:28 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Originally Posted by Warchild View Post
What was the purpose of the LCD screen?
To show Aquasuite etc. It's not connected up yet but I had it on last night. I still have a bunch of wiring to finish and tidy
__________________
If you don't like what I post don't read it.
  #262
Old 11-12-18, 11:19 AM
AlienALX's Avatar
OC3D Elite
Changed to an actual camera. Still work to do, so not ordered lights and backdrop yet.
Sadly when I pulled the masking it took off some paint. I was really mad, then realised I had loads of touching up to do any way in areas I missed etc.
Still very annoying though. Wiring is now pretty much finished.
__________________
  #263
Old 11-12-18, 11:21 AM
Warchild Warchild is offline
OC3D Elite
I think you should soften the lighting inside a little, because it completely drowned out the colour of your fittings. The red BP used was always a nice one.
  #264
Old 11-12-18, 11:25 AM
AlienALX's Avatar
OC3D Elite
Yeah, gotta get to that. Just needs dimming a bit tbh, it's way bright atm. I mean seriously it lights the house ffs.
Will take a break now (was at it til 2am, then up at 9 and been at it since) and then touch up the paint. I think it takes about 3 weeks to fully cure, and I put the tape on before it had. It only takes 24 hours to touch dry but yeah, it hadn't fully cured.
It's so nice not having any spinning hard drives. There's this eerie silence in here (I ran a Raptor, so you could always sorta feel it humming in your feet).
__________________
  #265
Old 11-12-18, 03:29 PM
AlienALX's Avatar
OC3D Elite
Turns out I had an issue with the clock. If you look at all of the pics before it went in it was much brighter. Fearing something was wrong (wiring) I popped the front (I can't remove it, it's now wired to the floor) and stuck my torch in. Screen went to full brightness. Eh?. So I removed the torch sure enough screen went dim.
*penny drops* it has a light sensor and dims at night. So to get around it I simply stuck an LED strip in there to feed it light.
Merry Christmas
__________________
  #266
Old 12-12-18, 09:09 PM
AlienALX's Avatar
OC3D Elite
So today I painted in the missing areas. I also made an IO cover as I totally forgot to do that and it looked like ass.
Tomorrow I want to try and make one more cover that I had an idea for on day one, but wasn't going to bother with because it was more aggro. Decided I may as well do it right, given all of the work I've put in.
Vega Devil 64 comes tomorrow, so hopefully I can button up the Triad and get it put to one side to go over to my mother's where it will become my away from home PC.
__________________
  #267
Old 13-12-18, 04:08 AM
looz's Avatar
looz looz is offline
OC3D Elite
Originally Posted by AlienALX View Post
Merry Christmas
Now program the lights to flash to the tune of this. :P
__________________
i7 8700k - 16GB - 2060 FE - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #268
Old 13-12-18, 07:12 AM
AlienALX's Avatar
OC3D Elite
If I can find the AlienFX media plugin I shouldn't need to program anything. Will have a look for that later today
__________________
  #269
Old 13-12-18, 08:30 AM
AlienALX's Avatar
OC3D Elite
IO cover fitted. Paint seems to be good, so I will move onto making the cover panel I want later today
__________________
  #270
Old 08-01-19, 12:39 PM
AlienALX's Avatar
OC3D Elite
It's finished. I've also taken some photos (and a video) with a half decent camera, capable of transferring how the build looks in person into photos (almost, we all know it's actually close to impossible)
Tech specs.
CPU - Intel Xeon E7 ES. 14 core 28 threads
Motherboard - MSI X99 SLi Plus!
Memory - 8x4gb DDR4 running 2133mhz
GPU - Nvidia Titan X (P, Pascal)
Sound - Asus Xonar U7 MKII external USB
PSU - Enermax Platimax EPM1500EGT 1500w
Storage
1TB Intel 2280 NVME PCIE SSD
1TB Sandisk 2.5" SATA
500gb OCZ ARC 100 SATA
240gb Sandisk SATA
250gb Samsung EVO SATA
Cooling
Radiators - 2x Bitspower Leviathan 240mm.
Reservoir - Bitspower Z-Multi tank (100mm)
Flow Meter - Bitspower hex RGB
Fittings - (red) Bitspower
Fittings - (black) Bitspower, EK & Barrow
Hose - 11/8 (OD/ID)
Fans - Bequiet! Silent Wings 3 (4x120mm 1x92mm)
Fans cont - 140mm (in PSU) 80mm Noctua Industrial (cooling floor)
Pump - DDC
Pump Top - Alphacool acetal
CPU block - Aquacomputer Acetal
GPU Block - EK 1080Ti/TXP
XSPC EC6 clear coolant
Electronics
Aquacomputer Poweradjust 3
Aquacomputer Splitty! 9
Aquacomputer Hubby 7 (X2)
Aquacomputer Aquaero 5 LT
Aquacomputer Farbwerk RGB controller
XSPC RGB splitter box (X2)
RGB memory module cooler (X4)
30CM RGB strip (X2)
7" 1024x600 touch screen
EVGA Powerlink
RGB Fan halo (X4)
Modifications
80mm industrial feet
Complete interior refit (skinned with 3mm acrylic, painted with Hammerite)
Coolermaster vertical GPU riser and ribbon
Custom front panel constructed from acyrilic, hosts -
Twin volt meters in front, with two way mirror/clock and coolant temp meter
Completely rewired
Bitfenix Alchemy 24, 8 and 6+8 pin GPU extensions (black)
Dodge SRT "Hell Cat" badge
Enormous thank you to all of those who helped me. Whether it be through advice, support, kind words or whatever else.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
