  #71
Old 11-05-13, 10:37 PM
Mgutierrez33's Avatar
Mgutierrez33 Mgutierrez33 is offline
OC3D Crew
Originally Posted by TBash View Post
You will know what that looks like shortly if i ever get around to getting mine finished,But on the bright side i ordered my acrylic side panel
Also your case is a thing of beuty mine looks like i hit it with a couple rocks your level of precision compared to mine is monumental,The only reason i think my build works is because its so over the top. But i think it will come together when it has the fit and finish of yours that is another story.
Boy you really know how to make a guy blush x-P. That means a lot to me, thank you. Srsly tho I really like your 600T and I'm really anxious to see how it turns out. I also just did an airflow mod on mine to take out the front mesh and the roof mesh so that I can also change the position of the radiator and fans. Werth! I also redid the cable management a tiny bit, I'mm update everything in a full fledged build log once I get the money together to change out all of the parts I really want to change out
__________________
Corsair Graphite 760T : Sabertooth 990FX R2.0 : FX 8350 @ 4.7 GHz : 8 GB Vengeance LP Low Voltage memory @ 2133 MHz : PowerColor AXR9 280X (1100 MHZ core, 1600 MHz mem) : Kingston HyperX 3K 240 GB SSD : Cooler Master Glacer 240L : Fractal Design Newton 800W PSU : NZXT Sentry 3 Fan Speed Controller
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
