Thread Tools Display Modes
  #11
Old 08-04-11, 11:33 PM
Karlos_the_n00b's Avatar
Karlos_the_n00b Karlos_the_n00b is offline
OC3D Crew
If its a gaming only rig mate then people say that the 2600K isn't worth the extra money for the performance diffrence between that and the 2500K. http://www.tomshardw...ew-32155-4.html
As others have said, the vengeance memory won't fit under the D-14. This is a list of memory that will fit: http://www.noctua.at...ts_id=34&lng=en
Personally if you don't mind splashing out on it then I would go for the corsair HX 1200W myself if your thinking Tri-SLI as its got all the connections you'll need and its gold rated and will last you a long time.
I'd also stick with the 570's and get 2 now if you can, or as soon as. People say that there a better alternative to the 590.
If you are running SLI though I would get a case with better airflow than the antec as on the UD7 those cards are right up against each other. I'd personally go with something like the fortress http://www.bit-tech....t02r-w-review/1
Just my thoughts. Hope they help.
  #12
Old 09-04-11, 06:13 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Hi your rig sounds alright and as Karlos stated the Hx I think he meant Ax1200 which is the gold series and listen to the boys here about cases and ram as they helped me heaps with my new rig set up. BTW enjoy the build and your new rig.
Ex.
__________________
DRAGON'S MIST
Coolermaster H500P White ARGB=AMD Ryzen 3700X=MSI Prestige X570 Creation=Intel Optane SSD 9 480GB PCIE=32gig 3600Mhz White Dom Plats RGB= Sapphire RX5700XT Nitro Plus=Coolermaster ML360R ARGB=MSI Optix MPG341CQR=Roccat AIMO 122=Corsair Force LS 960GB=Roccat Kone AIMO White=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with RBG strip=Windows 10 Pro=Thrustmaster T16000M HOTAS=Razer Firefly RGB CE=Chasepower Pure Sinewave UPS
  #13
Old 09-04-11, 08:52 AM
Pat123 Pat123 is offline
OC3D Elite
Yeh you're definitely gonna need a bigger case. And as for everything else once you've swapped the RAM which has already been mentioned it should be a killer rig. I wouldn't get 2x 570's yet i'd wait until the prices drop and one isn't enough to run all your games. Also I wouldn't bother tri sli, it seems like a pointless act for the minimal benefit imo. I'd also be tempted to save some money and go for the AX850W it'd be more than enough for SLI and everything else you're getting.
__________________
  #14
Old 09-04-11, 12:47 PM
OC3D Crew
Ex.
Yes I did mean AX, sorry. In a rush when I posted that last night sorry.
Edit: I´ve put a 60GB SSD in my better halfs rig. WIndows 7 is about 30GB an then we´ve filled about 20GB with the games she plays the most and then the rest are on a storage drives. 60GB is enough as long as your willing to manage it. If that sounds like to much of a pain then go for a 120GB drive instead.
Been thinking about Tri'SLI too. You might want to look into that cus as one of the other guys sorta mentioned, SLI doesn´t seem to scale that well but in the end mate your the only one who has to like your rig.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
