PinkCitizen
Hello there,
My first OC3D post! Would appreciate some guidance on a new build I am planning for 60+fps 3440x1440 ultrawide gaming to support a ROG Swift PG35VQ Gaming Monitor - 35 inch, Ultra-WQHD, HDR, 21:9 Curved, 200Hz, G-SYNC™monitor and to simultaneously stream to Twitch on 1080p60 following OBS resizing to deal with the aspect ratio.
Country: UK
Budget: 3K or whatever is reasonable for the requirement
Link to PC Part List
https://uk.pcpartpicker.com/list/qHn8BP
Further system requirements and notes re. proposed build:
- Build to last the next 5 years. I am still rocking an i7 2600k since 2011! So in 3 years time I could get a Volta Ti and up the FPS on current gen games.
- I would have considered a 1700 Ryzen build but I am concerned about the single core performance in the long term and I am not sure if it could support gaming on the required res and frame rate whilst simultaneously stream on 1080p60.
- Is it worth waiting for CoffeeLake as an alternative for this build? If so, do we know rough ETA?
- I am highly sceptical that Vega single card performance will be eclipsed by the 1080ti. Do we have rough ETA for new GTX cards and based on historical performance would a 1180 likely outperform and 1080ti?
- I could consider an i9 7900x CPU but I am concerned that the thermals will be an issue and it's likely to be an overkill.
- I recognise the ridiculous 28 PCIE lanes limitation of the chosen CPU but thankfully I am not a fan of SLI / Cross-fire.
- I have proposed the i9 7820X due to Turbo Boost 3 performance. Though tbh sound like I will be overclocking that one to 4.8 like in OC3D review video.
- I already have a 1200w power supply and will buy the monitor when it's out.
I would welcome your feedback, I tried to look up a similar build requirements on YouTube and the interwebz but I am hitting a brick wall!!
Thank you
Country: UK
Thank you
