Go Back   OC3D Forums > [OC3D] Forum Teams > Redline Folding @ OC3D - 98860
Thread Tools Display Modes
  #1121
Old 19-06-12, 07:47 PM
aicjofs aicjofs is offline
Newbie
Swapped out the 2600K with the 3770K @ 4.8ghz, added maybe another 5000PPD, (Except the wifes brother is back from college and staying with us, and gaming on it all day) I wanted to hit 100,000PPD a few more times this last month but WU's aren't cooperating.
I'm 90% sure I can get this 3770K at 5Ghz stable. I popped the IHS off and doing direct die contact with the water block but the die is convex. Depending on block placement I get 2 or 3 cores at 72C full load, and 2 or 1 at 82C, re-positioning the block and the results switch vice versa. This is with LinX linpack, folding doesn't push the temps on any core past 68C so I'm content with leaving it. I debate lapping the core, I did numerous A64's but those dies were larger and more square, this Ivy Bridge is very rectangle and small. It's harder to keep and even pressure.
  #1122
Old 21-06-12, 09:17 AM
SmoulderingCircuits SmoulderingCircuits is offline
OC3D Elite
4.8Ghz and working is better than lapped and dead.
__________________
Subroutine
Lubuntu 12.10 | 2880x1024 | AMD E-350
  #1123
Old 21-06-12, 04:59 PM
Newbie
Haha so very true! It's a good 12C cooler then with the IHS on, so probably will stop while ahead. I've done so many die, it's actually hard to kill them if you use the right process. Kind of relaxing work actually, listen to some music, and lap for an hour or two, come back later and do it some more, it's a slow process. The problem here actually is that extreme rectangle shape, you can't help rounding the very edge when you lap but doing it poorly and you end up with worse temps then had you just left it alone.
This thing is flying through the work units though.
  #1124
Old 26-06-12, 03:30 PM
xovius xovius is offline
Newbie
I just reached the top 100 of the team!
__________________
Asus Z170 Pro Gaming - Core i7 6700K - MSI 1080 - Corsair Vengeance 2x4gb 2400MHz - Samsung 950Pro M.2 NVME - Corsair RM750X -CM Master Case 5 Pro
Heatware Link
  #1125
Old 27-06-12, 10:01 AM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
Congratulations Xovius
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #1126
Old 27-06-12, 10:33 AM
CPMFW's Avatar
CPMFW CPMFW is offline
OC3D Elite
Congratulations for top 100 Xovius
i still got a long way to go to reach top 100
__________________
  #1127
Old 28-06-12, 06:23 PM
zorin1 zorin1 is offline
Newbie
Are you trying to catch me?
Matt
  #1128
Old 28-06-12, 07:56 PM
Newbie
Matt
Should be at the million in a couple of weeks
When I catch you however depends on how fast you run
__________________
Heatware Link
  #1129
Old 30-06-12, 01:26 AM
kilobravo kilobravo is offline
OC3D Elite
Send a message via MSN to kilobravo
My 3930k is up and running.Installed ubuntu linux client and got a 6901 to start with.
TPF at 15m13s ,100k ppd calculated with Fah bonuspoint calculator
__________________
  #1130
Old 01-07-12, 01:52 PM
OC3D Elite
Nice one man
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
