Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
Thread Tools Display Modes
  #1
Old 30-08-13, 08:55 AM
Lazlo's Avatar
Lazlo Lazlo is offline
Advanced Member
Z87-UD4H Onboard Sound vs Xonar DS vs new Xonar
Hello everybody,
this is my first thread. Hope I'm doing everything right. I would like to hear an opinion of the audiophile peops around.
I have a Z87X-UD4H by Gigabyte which sports the ALC898 Codec. Specs wise its supposed to have a 110dB SNR and a gaming headphone amplifier that is able to drive 600 Ohm Cans.
I have lying around an Asus Xonar Ds soundcard which is supposed to have a 107 db SNR. And I was never really content with the mic in functionality.
I was also thinking about possibly buying a new card.
I'm using a Sennheiser PC-161 Headset ( I would guess that's about medium end) for gaming and creative T20II (good bang for the buck) for normal use. I have seperate HIFI equipment to watch movies and listen to music.
To be honest I didn't recognise a noticeable difference between the new onboard sound and the old Xonar DS i had in my old rig. In contrast to my old board.
Now I'm wondering. Is the ALC898 especially good for onboard? Is the Xonar ds not that good for a discrete sound card? Is my hearing deteriorating? Are my headset and speakers not good enough to hear the difference?
And important question: Should I think about buying a new soundcard.
On a side note with the DS i always had the problem that the mic picked up sound from the headset and there was no option for noise canceling in the software. Do other Xonar cards have this option. The onboard has it and it works like a charm.
Opinions would be greatly apreciated. I'm kind of undecided at the moment.
Greetz Lazlo
__________________
"The road to hell is paved with good intention."
  #2
Old 30-08-13, 09:33 AM
tinytomlogan's Avatar
The Guvnor
If you have both why not save some time and just TRY both out and see what you like.......
#statingtheingobvious
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 30-08-13, 10:05 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
#thisisnttwitterdude #yolo
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #4
Old 30-08-13, 10:07 AM
Lazlo's Avatar
Advanced Member
I kind of did that as I wrote in my post. But thinking about it I will do a hands on test with my audiotechnica ath-m50s.
If anybody has the spare time to give me some info on the mic in noise canceling features of higher grade / different Xonars it would be still greatly apreciated though.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
