mrDMxtreme
So now that i went under water i want to have a new OC on my 2500k, BUT the thing i'm confused about is how much volts i can put through it now that temps are an issue of the past
i've been looking around here and i saw older posts saying that for a 24/7 OC you should use max 1.38v but newer posts say that a safe 24/7 max is actually 1.4v or 1.425v ????
		 leaving me confused.
next i tried google and apparently intel says its safe to use up to 1.52v but thats obviously TOOO high for a 24/7 clock.
SO can ANYONE provide me with an actual link to some legit site from intel or something that states a max safe voltage for 24/7 use at 100% load.
Until someone awesome on here shows me an actual number i will try to stay under 1.4v but obviously try use the lowest volts for a 5GHz clock (i'm actually running at that, but after like 30min of p95 1 core failed
		 , and i'm at 1.375v max temp of 63
		 ) gonna try 1.38 then 1.385 then 1.39 but hopefully i don't need to go that high)
