AlienALX
Well-known member
To find a game in the list press CTRL F. Then type in the name of the game you are looking for, as these are not added in alphabetical order.
I was thinking about doing this the other day, but was thinking on how I should format it.. Now I've had an idea that should work, keeping it nice and simple..
The object is to get a detailed and precise list of games and how they work in SLI/Crossfire. Obviously I will need help from you Nvidia guys but I will do what I can for AMD !
So the formatting is as follows -
Multi GPU type - CFX or SLI here.
Game - Game name here.
Does it work - answer here and brief explanation if you have any information.
Now I know AMD users can basically look through a list of profiles to see if Crossfire is listed which is nice, but this does not give you exact info on how well it works etc.
Any way, let's get the ball rolling.
Multi GPU type - Crossfire +SLI
Game - Crysis 3
Does it work - Perfectly on both
Game - Far Cry 4
Does it work - Yes it actually seems to work OK. However, Duna engine supposedly does not support Crossfire at all but I have found no information regarding when Crossfire was implemented. It seems to work fine, though.
Game - Fallout 4
Does it work - Yes. You need to be running Crimson 16.1.1 and version 1.2.37 of the game. Please read thread for instructions on how to do that.
Game - Just Cause 3
Does it work - No. According to the creators JC3 does not support multi GPUs of any type or sort. There is news that this game is going to be re-released in DX12 so we can only hope that SLI/CFX works by default using DX12's multi adapter.
Game - Mad Max
Multi GPU type - Crossfire + SLI
Game - Call of Duty : Black Ops III
Does it work - Yes but it's not perfect. Flickering textures are relatively common and I have had the game crawl into the single FPS a couple of times quite far into the game.You also can not use MSI Afterburner screen overlays as this will result in missing textures. SLI issues are -Almost Perfect, does suffer from some microstutter and the occasional frame drops mainly when recording at 4K with Shadowplay
Game - Middle Earth : Shadow of Mordor
Game - Tomb Raider
Game - Dying Light
Does it work - Yes. However, like BLOPS III there are issues with flickering.Performance is good, though.
Game - Trine 2
Does it work - Perfectly.
Game - The Witcher III
Does it work - Almost perfectly. Hairworks will sometimes misbehave.
Game - Dirt : Rally
Game - Battlefield 4
Game - Metro 2033 Redux
Game - Metro Last Light Redux
Game - Sniper Elite 2 & 3
Game - Grand Theft Auto V (GTAV)
Game - Thief
Game - Crysis 2
Game - Dead Island
Does it work - No
Game - Dead Island : Riptide
Game - Borderlands
Game - Borderlands 2
Game - Borderlands : The Pre-sequel!
Game - Wolfenstein : The New Order & Wolfenstein : The Old Blood
Does it work - No, does not work at all in either Crossfire or SLI and never will according to the developer.
Game - Call of Duty : Ghosts
Does it work - Crossfire - Works very well, though some micro stutter was evident. SLI - Yes but suffers from extreme microstutter, frame drops and optimisation issues.
Game - Project : Cars
Does it work - Perfectly, though it has been reported that smoke and particle effects may cause slowdown.I did not notice anything of the sort.
Multi GPU type - SLI
Game - Elite Dangerous
Does it work - Perfectly, does suffer from occasional frame drop but that is believed to be a game issue. In terms of Crossfire X according to posts on the Frontier Forums there is no Crossfire profile for it so Crossfire will not enable, however I cannot test or confirm this issue.
Game - Titanfall
Does it work - SLI - Yes but suffers from weird lights popping up in the maps through walls and the occasional texture issue, game is also has a frame rate cap locked to the monitors refresh rate.
Game - Dirt 3
Game - Bioshock
Game - Bioshock Infinite
Game - Batman : Arkham City
Does it work - SLI - Yes but with what seemed like poor scaling, based of benchmark runs I did when testing GTX 780Ti SLI compared to GTX 980Ti SLI @4K
Game - Call Of Duty : Advanced Warfare
Does it work - SLI - Yes but suffers from extreme microstutter, frame drops and optimisation issues and also some mouse input lag when SLI is enabled.
Game - Batman : Arkham Knight
Does it work - No. Does not work at all.
Game - Split/Second AKA Split/Second Velocity
Does it work - Very good though there was the occasional stutter. However, IIRC the game does this on a single GPU too.
Game - Batman : Arkham Asylum
Game - Fallout 3
Game - Alan Wake
Game - F3AR
Game - The Sims 4
Game - Heroes of the storm
Game - Star Wars : Battlefront
Does it work - Does not yet work at all. I have spoken to AMDMatt and he said that DICE were working on an update.
Game - Rise of the Tomb Raider
Does it work - It works and scales well but is rather buggy.
Game - Far Cry 3
Does it work - It works OK, though some stuttering was evident. Note, you need to change Vsync to 1 frame and disable the frame buffer to prevent further stuttering.
Game - The Crew
Does it work - Yes but the game is locked to 30 FPS. I will be testing any way to circumvent this soon, watch this space
Game - Assassin's Creed : Rogue
Does it work - This does not work in Crossfire at all. Not even by enabling the Black Flag profile
Game - Splinter Cell : Blacklist
Does it work - Seems to work perfectly.
Game - Rayman Origins
Game - Far Cry 3 : Blood Dragon
Game - Firewatch
Does it work - No. Does not work at all though I doubt it would be needed any way
Game - Xcom 2
Does it work - Right now the only way is to use the profile for the original Xcom. But it seems to work very well and gameplay was very smooth. Also note - right now the game does not support 4k so you need to add that manually. Please see thread for instructions.
Game - Gears Of War
Does it work - Works perfectly.
More to come.....
Changelog
Update 16/01/16 added Metro 2033 Redux and Metro Last Light Redux.
Update 16/01/16 added Sniper Elite 2 & 3
Update 16/01/16 added GTAV
Update 16/01/16 added dashes to make it easier on the eye.
Update 16/10/16 added Thief to the list. Also added Dead Island, Dead Island : Riptide and Crysis 2 Maximum Edition.And Borderlands (all). Added both Wolfenstein games.
Added Call of Duty : Ghosts. Also added - Project Cars.
Update 17/01/16 - Added several games and more SLI information posted by Damien C. Added Batman AK CFX.Added Split/Second.Added Bioshock.Added Batman AA.
Update 18/01/16 - Added Batman Arkham City.Added Fallout 3.
Update 19/10/16 - Added Alan Wake. Added F3AR, Heroes of the storm & The Sims 4
Update 04/02/16 - Added Rise of the Tomb Raider & updated Fallout 4 status accordingly.
Update 05/02/16 - Added Far Cry 3
Update 06/02/16 - Added The Crew (UBI)
Update 08/02/16 - Added Assassin's Creed : Rogue and Splinter Cell : Blacklist & Rayman Origins
Update 10/02/16 - Added Far Cry 3 : Blood Dragon.
Update 12/02/16 - Added Firewatch. Added Xcom 2.
Update 13/02/16 - Added Gears Of War (2007)
Game - Crysis 3
Game - Far Cry 4
Game - Fallout 4
Game - Just Cause 3
Game - Mad Max
Game - Tomb Raider
Game - Dying Light
Game - Trine 2
Game - Dirt : Rally
Game - Thief
Game - Crysis 2
Game - Dead Island
Does it work - No
Game - Borderlands
Game - Titanfall
Game - Dirt 3
Game - Bioshock
Game - Fallout 3
Game - Alan Wake
Game - F3AR
Game - The Sims 4
Game - Far Cry 3
Game - The Crew
Game - Firewatch
Game - Xcom 2
Game - Gears Of War
More to come.....
Changelog
