JayCobs
I am out of ideas at this point. I have a bubble in my EK-Supremacy Copper Plexi block that won't pass through...
In the first shot the bubble is in the middle circle of the CSQ design. In the second shot it's easier to see due to it being magnified through the plexi.
For more pictures of my build you can search Tha Leviathan in the Project Build Logs.
My loop is as follows:
Dual MCP655 pumps - 480 rad - 480 rad - 480 rad - EK Supremacy Copper Plexi CPU block - Bitspower Memory block - Heat Killer 79X0 - Heat Killer 79X0 - Bitspower 150 Res - Dual MCP655
I've been running this loop for months without hiccup. The bubble has been there for the past 3 - 4 weeks. This bubble has become a thorn in my side. I have tried EVERYTHING to get the bubble to pass. I've tilted my build 90 degrees backwards which gets the bubble to exit the block. Everything is fine. However, a few hours or less later it appears again. I have recently "rinse and repeated" this 4 times, each with the bubble reappearing. I also rerouted my loop so the CPU block is first after the pumps. This didn't pop the bubble either.
I do not have air anywhere else in the loop. I don't have trickling, sloshing, or ticking noises. My loop is dead silent. This bubble grows and shrinks. As I am typing this it has become larger than the pics I have provided. Also my temps are fine. At time of typing My CPU is 29 Celsius, and GPUs are 27 degrees Celsius. I do have the CPU block and jet plate installed properly with the recommended inlet and outlet. I've read air in your loop can harm performance, but it doesn't seem to be harming mine. Unless I'm going to drop 5+ degrees with the bubble popped. I have also read people adding liquid detergent to the fluid to help with bleeding. I'm using Mayhems Pastel White, and I'm not sure how to implement that.
I am at the end of my rope. When I look at my build and see the bubble I feel the loop is not finished. Any ideas on how to fix, or pop this bubble??? :huh:
