AlienALX
Well-known member
Right, seems my egg hatched and I am about to come into some money. Stupidly I can't keep any of it, or I will end up homeless (stupid long story about a dumb govt here) so I have decided to build a new gaming rig. Note, gaming only nothing else.
At first my choices may seem odd, but I will explain that in a bit.
If any of this is junk or can be improved on tell me please. I'm a little bit out of the loop.
For the case I chose this. This isn't flexible as you will see why.
I'm going to call it Mike Tyson, so black out everywhere. No RGB unless it comes with the parts and in which case it will all be set to white or off. I've got two tarty rigs I don't want another. OK, so this is why I chose that case.
As I said, the rest may not make sense but it will by the time you're done reading.
Board.
CPU will be a 3950x.
RAM (32gb 3600)
Like I said, I am deliberately avoiding RGB.
Two of these. In the SODIMM thing on the board.
This
This.
For which I have this.
Fans.
Push pull all the way through. I will be using two rads. 360 top, 240 bottom. It will all be Bitspower. Everything, all from their new range. Probably going to stick to black soft tubing as I love it.
OK, now this is why I have chosen DTX.
If you floor mount a rad and two sets of fans it eats the board. So this will have everything all stashed on the tiny board, with the rest of the space used for water cooling.
Hopefully I can order that soon. Tomorrow or day after. I will order the water stuff on Friday.
As I said, looking for reasons as to what you would change and why.
Board.
	RAM (32gb 3600)
	This
	This.
	Fans.
		 .  What are the timings on that ram and what cpu block are you going with?
		 . We had the same thing in January with the DWP. Thousands went into our bank account from them, So I rang for clarification and it was all what they owed us since 2015 when they changed us to ESA. Any idea which VR headset are you are liking the look of?. I have the Rift S and already pre-ordered Half Life Alyx.
