My Overclocking Journey!
Not the most professional guys doing like overclocking BUT I do my best!
Using Windows 10 64Bit.
Right my stock Clock's are
Clock Speed - 1253Mhz Boost 1355MHz
3D FireStrike Extreme Score - 8469
http://www.3dmark.com/3dm/7919271
I went up in stages of 10Mhz at first only the GPU Clock speed I did the Memory later, Using Zotac's Overclocking software seem's simple and easy to use, My Power and GPU target was 111% and 91c.
I didnt push my target power and GPU Temp target when adding 30Mhz to the Clock speed so I dont have the results for that but I got a score of 8472 on 3d mark Firestrike extreme so a clear 98 difference in points.
Clock Speed - 1263Mhz Boost 1365MHz
FIRE STRIKE EXTREME - 8565
http://www.3dmark.com/3dm/8063553?
Clock Speed - 1273Mhz Boost 1375MHz
FIRE STRIKE EXTREME - 8570
http://www.3dmark.com/3dm/8063626?
Clock Speed - 1303Mhz - Memory 1830Mhz Boost 1405MHz - Added 50Mhz
FIRE STRIKE EXTREME - 8712
http://www.3dmark.com/3dm/8063759?
Clock Speed - 1313Mhz - Memory 1855Mhz Boost 1415MHz
FIRE STRIKE EXTREME - 8726
http://www.3dmark.com/3dm/8064250?
This is where im kinda stuck so any advice or trick's haha please do reply! Wanting 9k I know I can do it! I know ive not mentioned Temps but they're staying around the 60c to 65c so very cool.
Clock Speed - 1323Mhz - Memory 1858Mhz Boost 1425MHz
FIRE STRIKE EXTREME - 8900
FIRE STRIKE ULTRA
http://www.3dmark.com/3dm/8066772?
Hoped you liked these score's im still trying with this card and I think it can do alot more!
