Lynx
Hi, :wavey:, i have a Q6600 And hoping to overclocking it to 3.4GHz or more,
i was wondering whether i should go for the Zalman CNPS9500 LED HSF or the Swiftech H2O 120 Compact water cooling kit, i like the HSF as its easier to install, also cheaper, but i like the thought of saying, "Hey i have a watercooled pc @ 3.4GHz"
Any other suggestions would be appriciated.
Also wat PSU do you suggest i use? :/
Willing to spend £90 MAX
Zalman CNPS9500 LED
http://www.custompc.co.uk/reviews/81787/zalman-cnps9500led.html
http://www.custompc.co.uk/reviews/125910/swiftech-h2o-120-compact.html
Zalman CNPS9500 LED
