YES another 6990 question
KING_OF_SAND
Only post if you have a "VISIONTEK" 6990.
Can this card be overvolted?
I know visiontek is renowned for having non overclockable cards in terms of overvolting do to a lock (or something) in there BIOS.
Is this the case with this card?
Don't think many people have them, not seen a single review on them. Are you looking at the $720 one on Amazon?
And maybe they are cheap because it looks like the only defining thing about the card is the fan sticker, basically unbranded.
Think I'd stay away from no name brands. Even if it is reference. I know you have a gift certificate. Maybe look at getting 2 nividia cards or 2 amd's instead. Try to go with something (we've) all heard of maybe. Just MHO.
i found a diamond card that i just ordered.
also i prefer to go with single slot cards because it takes up less space.
off topic but
AMAZON support is some of the best support i have EVER SEEN!
Would be best to wait until the PowerColor, HIS and Gigabyte cards come back in stock.
I'm assuming your gift card doesn't expire sometime dangerously soon?
I have heard nothing but bad things about HIS, i lost respect for Powercolor a while back, AND i was just now considering the gigabyte 6990 but it costs more. I have had no problems with Diamond, and if i do RMA is easy as can be through Amazon.
If you had $800 for me I would support you too
