Yep yep my Rig ;)
Bulletz0rs
yeah guys so heres my rig :) =] hope ya like it
Specs are in my sig ;)
specs in your sig alone are NOT allowed for rig galleries :confused:
Q: what happens at a later date, if you upgrade AND change your sig in any way?
A: this post then becomes incorrect and usless to anyone :mad:
please include your specs in the original OP
ty for your coop :)
Lots of cabling :/
You should change the cabling around on the d14 fans so you cant see a cable on top.
Looks alright though!
like anything wit ha D14 in it... like JR94 said, re-orientate your D14 fans 90° so the power
cable is at the bottom, so it is stealth powered... but looks good. need more light for photos..
airdeano
Needs a serious GPU upgrade and some cable tidying. Love your orange xigmatek case fans though, same ones as I use.
