XSPC Rasa 750 RS 360 Question
KTCRITCH
Can I switch out the 1/4" ID Barbs and Tubing and replace it with 1/2" ID Tubing and 1/2" ID Compression fittings? Will the compression fittings fit in the stock barb holes? Do the compression fittings become smaller at the end to insert into any water block hole and just fit the tips to whatever tubing matches it? Any answers relative are well appreciated!
My Apologies. [font=Tahoma, Arial, Helvetica, sans-serif]7/16" ID x 5/8" OD, Could I replace this with the 1/2 inch ID tubing and compression fittings? stock it has [/font][font=Tahoma, Arial, Helvetica, sans-serif]G1/4" to 1/2" barbs.[/font]
should not cause any problems, just make sure that you match the ID and the OD of the tube and compression fittings.
I personally like Toms method 1/2 barbs with 7/16 tubing no need for clamps at all keeps it cleaner looking imho and cheaper than compression style fittings
I just want the fancy look factor. Large tubing looks great with compression fittings in my opinion. Plus I have lots of money to throw around.
